CarnationSailor's avatar
May 23, 2021
Satellite Pre-Wiring
I have a 2015 Crossroads Rushmore Springfield and am trying to understand how it is pre-wired for satellite. (I want to add an RF Mogul Eagle permanent-mounted antenna on the roof and connect it to a Dish Hopper 3 receiver.)
There are 2 coax jacks on the roof. Does one go to the entertainment center and one to the bedroom?
In the entetainment center, there are 3 coax cables in the cabinet above the TV. I assume one would attach to the receiver's input, but since the receiver's output is HDMI, what are the other 2 used for? (Maybe back in 2015 the receiver's output would have been coax?)
There are 2 coax connections behind the TV. One goes to the antenna/cable TV input. Was the other intended to connect the TV to the satellite system? That is, does it connect to one of the 3 coax cables in the cabinet above?
In the bedroom, there are 2 currently-unused coax jacks. Are they part of the satellite system pre-wiring. (Neither the jacks behind the TV or in the bedroom are labeled.)
Any thoughts on this will be appreciated.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
