BFL13
Aug 09, 2014Explorer II
Saved by Trimetric and Solar Monitor Comparison
Been some threads about whether you really need two monitors if you have solar as long as you have a Trimetric (or that "other one" :) )
As we know, the solar monitor shows all the amps the controller is out-putting (is that a word?) while the Trimetric only shows the amps going into the battery. If the solar monitor shows more amps than the Trimetric does, then that means the solar is running a load plus charging the battery.
So I noticed the solar monitor (on the Eco-Worthy itself, not a remote) showed 4.58 ish amps while inside the trailer the Trimetric was acting weird, showing 2.0/1.8 flashing back and forth. So I thought I had a mystery load of about 2.5a.
Pulled all 12v fuses one at a time, no joy. Turned off solar and Tri now showed 0.3a steady. Aha, that is normal with the fridge burner not on. So it must be something to do with the solar itself, but what?
Much poking around and trying this and that then noticed some green corrosion goop on the battery pos post the solar was onto along with a bunch of other terminals (breaking Mex's Law that you should only have one thing connected to any battery post, using a buss if you need more connections)
Cleaned that all up and Shazam! No mystery load at all, it was just the solar wasn't all getting through to the battery.
I never would have noticed that until the green goop had become so huge even I could see it right away, if I had not the two monitors, since the solar monitor was showing the actual output ok. In this case it was the Trimetric that had the funny number.
Now I am wondering if my complaints about the MPPT solar not delivering as many amps as I am entitled to, might be due to that, and not to the heat lately as I had thought. We will see about that
next chance I get to see full output from the solar. (too late today)
Not saying everyone should rush out and get more monitors (they cost money), but am saying there are advantages to having more than one.
