TurnThePage's avatar
TurnThePage
School Me on Solar Panels
I recent started a thread about lifepo4 battery configurations, 12v/24v/etc. I think I'm settling on four 230 AH batteries, and will likely keep them in a 12v config.
Now I want to figure out the solar. I am mounting the panels in a permanent position on the roof with no adjusting for best sun.
I see lots of systems where they are very close to the roof and wonder about that. Panels get hot. My intention is to run tracks the length of the roof and mount on them, maybe keeping the panels 4-6 inches off the roof. That will provide good ventilation and even shade for the RV. It will also reduce shadows on the panels from other stuff on the roof.
Now my questions:
I'm not familiar with current wiring methodology. Are they all the same now? I hear people mention MC4 connectors. Is that the standard? Do I need to worry about that or will all the hardware be compatible right out of the box?
What about the panels themselves? I've understood that monocrystalline is superior to poly for RV use. Is that still the case? It sounds like most panels are manufactured with shade tolerant diodes built in now. What other considerations are there?
  • 2" spacing is adequate, mine are 6" to eliminate shade from the A/Cs. MC4 is a standard connector. Bypass diodes provide better shade tolerance for serial panels and more power than parallel panels. You'll need a MPPT controller with input voltage spec greater that the combined Voc of the serial panels.
  • Wire in series and you won't need thick wire or a combiner box. Tilting for best sun will gain about 50% more harvest.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 01, 2025
