tvfrfireman's avatar
tvfrfireman
schwintek slide issue
Have been struggling with a 13 foot slide on our DRV fifth wheel for months and replace almost every part. I finally noticed while cleaning and waxing the bottom of the slide some slight depressions where the rollers travel along the slide while it moves in and out. I then realized the slide has settled very slightly in these grooves. The bottom of the slide is made of one inch plywood with a white protective barrier on the bottom that could be melamine. I called my dealer and they knew all about this problem and told me they installed eighth inch stainless strips a bit wider than the rollers to bring the slide up so the teeth of the drive gears don't bind in the track mounted to the slide. I was wondering if I could use aluminum for the same purpose as I can cut aluminum. Have any of you folks done this to the troublesome shwintek slide? This has been an ongoing nightmare and fails at the most inopportune times. I would be grateful for any help in this issue. Thanks, David
