hpdrverExplorerApr 05, 2015Schwintek slideWe had a wire come loose from our slide motor and need to replace motor. However slide is in and need to open slide to get to motor retaining nut. Manual said to unplug both motors from controller and...Show More
bid_timeNomad IIIApr 05, 2015Yes, provided you unpluged just the motors at the controller. Unplugging the controller won't work. Go to LCI1.com lots of good info.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentSchwintek slide jammed - shifted backLeaking Schwintek slide railSchwintek slidesSchwintek slideSchwintek slide improvements
