selah44
Jun 10, 2013Explorer
joebedford wrote:
Access to the Schwintech slide mechanism in my rig is from the outside. Just unscrew the cover plate.
Thank you. I don't remember seeing a cover plate but will double check. As far as the motor being bad, because the unit had two motors on the controller, I swapped the electrica leads from the controller to the motor and used the good motor's wiring harness to assure power going to the bad motor. I also used the override function on the controler but still no luck. The dealer is far away and all local RV dealers will take months to get to it...otherwise I would drop it off at an authorized dealership. Thanks for the help.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
