faucet1's avatar
faucet1
SCS Fridgette Need Parts on 2002 Diplomat
Just had the expansion valve replaced on the dash A/C and need to replace the drier. Can't seem to find a part number since it is painted black(OEM). I know SCS folded and was bought out, but I am hoping I can find the part locally. Anyone have an idea other than just taking the part to local parts stores to try for a match? Thanks David.
  • j-d's avatar
    j-d
    Explorer II
    Many "receiver driers", used in the high side (the smaller hose) are compatible with both R134A and the old R12. So the one you get is likely to have a sight glass, BUT!!!
    You can't charge by adding R134A till the sight glass clears, like we used to with R12. The flow and the look don't let you see what it's doing.
    Charge by pressures. LOW (Suction, Large Hose) should pull down to about 20 and HIGH (Small Hose) shouldn't go much higher than 2.2 x ambient pressure. So if it's 95 out, HIGH shouldn't be much higher than the low 200's.
    Here's a pic of a Receiver Dryer cut open. Notice it's directional. Should be marked with Arrows or In and Out. The OUT has a tube that extends to the bottom of the "can" so only liquid refrigerant leaves exits the Dryer on its way to the Expansion Valve.
    OH! Be sure the new Thermostatic Expansion Valve (TXV) is wrapped with insulation, usually called PresTite. It'll keep humidity from condensing onto the TXV while it's in normal A/C operation. Dripping condensation is the least of the problem. The condensate will freeze and the ice causes the valve to stop the cooling process!
  • I probably was the culprit in their not choosing to install the drier at the same time, because I asked the question that if I saw bubbles coming through the drier while the initial recharging was going on....does that mean the drier is working. In retrospect, I should have requested that they install the drier at the same time. Shame on me not using my thinking cap. Wrong again as usual. Hind site is great. And Of course that will cost me again for another evac. I will take the old one into NAPA and see what they say. Thanks for the suggestion.
  • j-d's avatar
    j-d
    Explorer II
    Surprised the installer of the TXV couldn't furnish a Drier. All you should need is the Diameter of the connections, and the type of connection. By that I mean Flare, Barbed or Beadlock. Here's an "RV Drier" with threaded connections from ACSource in Phoenix.
    Try the local auto supply. Sometimes NAPA can access more stuff than the discount chains like Autozone, O'Reilly etc.
    If you're stuck, call Warren at ACSource. If Warren's stuck, PM me. Might have a back channel...
    Amazon Search Four Seasons Receiver Dryer
    Amazon Search Receiver Dryer
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
