I can't keep my Onan KY4000....H generator running unless I spray a continual mist of seafoam treatment into the air cleaner. Would this mean carb issue or control board issue? Thanks Len
FUEL could be a clogged carb, could be a bad fuel pump, or clogged filter
or Not enough gas in the RV tank, you do have at least a 1/2 tank right somewhere around 1/4 the generator pickup can no longer reach the gas the generator pickup is shorter than the drive engine pickup tube
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
