Ldworak
Aug 13, 2015Explorer
Seafoam Treatment
I can't keep my Onan KY4000....H generator running unless I spray a continual mist of seafoam treatment into the air cleaner.  Would this mean carb issue or control board issue?
Thanks
Len
Thanks
Len
RAS43 wrote:Yep and all of them want $11.99 to $13.99 a can plus never put it on sale. I'll take NAPA sale price of $6.99 or $7.99 all day long.The Texan wrote:
I get mine from NAPA. They have a sale 2X a year and I stock up on Seafoam and what ever else I need then.
All of the auto parts stores around here carries it.
RJsfishin wrote:jwmII wrote:
More than likely a fuel delivery problem. Tell us what year your generator is. If it is 8-10 years old the rubber fuel hose from the gas tank is probably hardened and cracked and sucking air. That will give you the condition you describe.
What part of this OP statement don't you understand ?
Quote:
I pull the fuel line off the carb while trying to start and its being presented in a continuous flow.
JaxDad wrote:Not on my 20 year old Kohler. I wish it did.Gjac wrote:RJsfishin wrote:I don't have prime on mine.
You don't have to crank the engine to check fuel flow.
The fuel pump is electric, and will run in the prime (off) position of the "start/stop" buttonGjac wrote:
I would disconnect the fuel line and crank the eng, does the fuel shoot out? If not disconnect the intake side of the line and suck on it then put your finger over it and see if it hold vacuum. I use a clear tube on the line to see the fuel. If your line is good and you get fuel out of the pump I would put the intake line into a gal of gas and a half can of Seafoam and run it for an hr under load after you flood the carb with Seafoam and let it sit per the instructions on the can.
If you hold the 'off' button down the fuel pump will run to prime the genny.
Slownsy wrote:
Where you get the sea foam from.
Frank
