rajivkohli's avatar
rajivkohli
Secondary Propane doesn't light appliances
Hi,
I'm a full time RV'er living in Alaska and New Jersey, and working anywhere there is a contract... On any coast :-)
I have a 10G Internal Propane tank on my Class-C Shasta 26' Motor-home. Often i come across situations where the Gas Station won't fill the tank after dark or the attendant is just not there.
SOOOOO - I added 2 portable tanks in the rear (This way if i run out of propane, I can just visit a HomeDepot/Lowes and exchange it 24hrs.
Setup:
The two tanks are installed on the rear bike rack and secured with the proper kit (Bought from Amazon). I have a A/B switch with regulator.
The primary tank has a "T" to hook up external portable tank (IN) and a BBQ (OUT). I believe it has a regulator, but not sure
Anyway, the problem is:
1) When I hook up the portable tank (On the ground) with a 3' hose to the "IN" port. I can shut off the internal tank and the appliances run off the portable. This works well if I'm parked for a long time - but not in a rest area or similar spot
2) I got a 25' hose custom made by a propane parts supplier online (Recommended by Camco which is a famous propane stuff supplier on Amazon)
3) I bought a "A/B" switch (I have 2 portable tank on the rear of the RV) - In total 3 (2 portable in the back) and 1 internal.
4) The portable tanks are connected in exact the same way as if it was sitting next to the internal tank (Where it worked before). The difference is that it is now 25' away and has a A/B switch (With Regulator)
Problem:
If I turn the internal tank OFF - My appliances should continue to be fed by propane from the portable tank.
They don't.
I opened the hose just before the "T" to see if there is propane coming. It is. I can smell it.
I also put a thumb on it and then released it. I can feel the pressure.
Q: Why are the appliances not lighting up then?
Someone in the RV park said that it could be because of the A/B Switch which has a regulator, also. Now, I have 2 regulators..
Please help
Rajiv
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
