mobeewan
Jun 30, 2018Explorer
dpgllg wrote:
Hello,
I just finished installing a television in the bedroom of our 5th wheel. I put the TV mount right over the spot labeled and secured with lag screws.
My questions now are:
How can I best secure the TV while traveling? Do they make a kit with straps etc. for this purpose? Where is the best place to purchase?
The power was easy but now I need to connect a coax cable from one of the two jacks in the ceiling to the TV. We use satellite for our TV. If I connect to satellite I should get the same channel that is on in the living room TV right? Unless I get a seperate DISH reciever I have to watch wahatever is on the recevier in the living room.
Are there any tricks or problems etc I need to know about? My wife is excited to get the TV in the bedroom so I really need to make sure it works to keep her happy!
Thanks!
Dave
Currently I use a satellite receiver with the trailer that is not HD. It has two sets of S video connections, two sets of the yellow, red and white RCA connections on the back and one HDMI connection on the back. I connected the TV over the dinette where the receiver is located using one set of the RCA connections. I needed the HDMI connection for the DVD player.
I bought a 20 or 24 foot long flat cable with the yellow, red and white RCA connectors on the ends. I connected one end to the second set of RCA outputs on the satellite receiver, ran the cable over to the corner under the overhead cabinet, then along the bottom of the cabinet to the end of the cabinet next to the entry door, then up the side of the cabinet, then along the ceiling next to the wall over the entry door, then turn 90 degrees along the ceiling across the entryway to the bedroom and then along the ceiling over to the set of RCA connectors on the bedroom TV. I used wide plastic cable channel from the satellite receiver over to the cabinet to conceal and hold the cable along with the power cables for the DVD player TV and satellite receiver going to the wall plugs. I then used plastic P shaped wire clamps along the underside of the cabinet to secure the wire until I got to the ceiling. Then I used to staple gun with wide Staples and held it Loose against the cable as I stapled to keep from piercing the flat RCA cable to attach it to the ceiling about every 12 inches. Works for me.
When I strung the RCA cable to the bedroom 20 foot HDMI cables were running close to $100. I got the RCA cable at Radio Shack for about $20. I don't have HD satellite receivers so the HDMI cable is overkill. 20 foot HDMI cables are running a lot cheaper now.
As far as watching separate satellite programs on each TV there's only two ways to do it. You will need a dish that has a dual lnb for connecting two separate cables. One cable will need to go to the trailer satellite input connection. The second cable will need to go directly to the second receiver which will mean a separate entry into the trailer.
Another method is to use a special AC powered splitter that is specifically made to split the satellite signal before the signal goes to each receiver. You will need to connect it to the wall plate for the satellite signal coming in then split from it to each satellite receiver. Regular cable Splitters do not work for satellite. The signal coming through the cable from the dish is a dual signal and the receiver needs both signals to work. If you use a standard cable TV splitter one signal goes to each receiver. The powered splitter sends both signals to each receiver.
