Ductape's avatar
Ductape
Seeking advice on 12v upgrade- Ch. 1: Batteries
Hello all, I'm preparing to upgrade the power system in the coach, and I would really appreciate some advice from the tremendous well of 12 volt expertise on here.
A bit about how we'll use it: right now we work and vacation, but we're getting set up for FT next year. We prefer to boondock, with occasional hookups just to dump etc. I estimate our consumption at around 35 AH minimum, 70 typical, and 125 if we pig out on power. We like shady campsites. Plan overall is to have enough battery to get us through 2-3 days between generator runs if we are too shaded, and enough solar to do the job for average consumption when we are in the sun. On a typical day we end up partially shaded and run the generator while doing breakfast, and get enough solar to do the rest while we are out and about.
Starting for now with the battery question: plan is for Lifeline AGM. Expensive I know, but I hate battery maintenance, and some of these will end up in sealed compartments. First question is to settle what size, how many, and where to put them?
Right now the coach has a rack in the front engine compartment, and there is a convenient space in the compartment behind the door where the converter and inverter are now. I would like to place 2 batteries in each space. Thinking at this time GPL-6CT, with 4 of those we'll have 600AH and it's a nice fit for the spaces. I could always go down to the GPL-4CT (220 AH), or I can fit 2 GPL-L16T (400 AH) in the storage bin.
Question- will the temperature difference between the storage bin and the exposed batteries in the engine compartment be a significant concern? There is no room to put all 4 in either space. To put all 4 in the basement I'll need to move further to the rear, and I don't like moving weight front to rear.
Q2- should I configure these as two separable banks, or just 1 big bank?
Any other questions I have not thought of?
For the other bits, which I'll ask about in subsequent posts (didn't want this to get too long), plan for now is to charge with a PD9280, and 300-500 w of solar.
Thanks in advance for your help!
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
