valhalla360
Jun 18, 2021Navigator
If the cooling unit is 150F (not sure of the actual temp but it's pretty hot).
- If there is minimal airflow, the air around the cooling unit may be 130-140F, so only a 10-20F temp difference.
- If you push 110F air in, that's a 40F temp difference which will extract more heat from the cooling unit.
That said, 110F can be problematic.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
