dougrainer
Jun 18, 2021Nomad
Do you still have the 29 foot Airstream? If so, that silver Metal exterior is NOT the best exterior to have in hot climates. Also, due to Airstreams curved body, the roof vent is NOT right above the refer rear Condenser fins. So, opening the lower door and adding a fan to blow UP will give you much better operation and cooling. Usually on Airstream's there is enough room to install a small 120 volt fan blowing up so you just plug it into the rear 120 receptacle the refer is plugged into. Doug
https://www.amazon.com/OPOLAR-Speeds-Powered-Powerful-Office/dp/B01MR2SEAR/ref=sr_1_15_sspa?dchild=1&keywords=120+volt+small+fan&qid=1624032510&refinements=p_n_feature_keywords_five_browse-bin%3A7899354011&rnid=7899353011&s=home-garden&sr=1-15-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyNlNLWlVCTjU1RThOJmVuY3J5cHRlZElkPUEwMzczOTcxM0NGSTBKR1EzUVhMQSZlbmNyeXB0ZWRBZElkPUEwMjQzNzMwMTlYSTBJVUdON1VGRSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
