- lostbytesExplorer
wolfe10 wrote:
Actually, by far the BEST location for the muffin fans is at the top of the condenser blowing out the roof/upper vent. Much more linear flow/less turbulence over the condenser.
Also insure that your refrigerator manufacturer's installation clearances ARE correct. Many have a space above the refrigerator which leads to both turbulence and the retention of heat.
Same for verifying clearance from back of refrigerator to outside wall. Too much is NOT good. It is all in your refrigerator installation manual.
I stand corrected on this one. - wopachopExplorerActually thats not true. Its not the most effective. Fans on the cooling fins i consider the most effective warm weather fridge modification. Next is additional fans in the back ventilation section. I think most fridges have a small one back there. I can hear mine rattling away sometimes.
- wopachopExplorerThe cheapest and most effective warm weather fridge mod you can do is the cardboard trick.
- wopachopExplorerHope it works out. Another trick i do during the summer is try to use more frozen foods. I got a beer in the freezer right now getting cold. Even stuff like leftover pizza can go inside the freezer instead of the fridge.
Oh...check this out. Cut a piece of cardboard the width of the fridge and 1 foot tall. STuff that to the bottom section of the fridge. It will retain cold air from dropping out every time you open the door. I did that last year and the same piece of cardboard is still there. Made a thread with pictures. - groundhogyExplorerOP:
Well, it’s back to being a fridge instead of a nice warm incubator. Im sure temperature wise it still needs improvement. I have not yet pulled out my thermometer.
I have the tiny (its significantly smaller than it looks on TeeWee) arctic air swamp cooler in there plus a little muffin fan.
I will likely upgrade the little muffin fan.
Also considering expanding the water tank on the arctic air. Maybe a largerupside down pepsi bottle. Kind of like those dog bowls with a 2 liter pepsi bottle. - wopachopExplorer
wolfe10 wrote:
Have you come across centrally located fridges? The lower vent is through the trailer floor.
Curious your opinion on fan placement for that type of setup. My manual wants me to put the fan down low in the floor space. I did that because it was easy. Trying to think of the difference between pushing air and pulling air. Turbulence as you mention. - wolfe10Explorer
lostbytes wrote:
To add to the above statements. If you use a fan in the back. Make sure propane RUNNING FLAME or pilot flame will not be interfered with. Those computer type fans should be ok but more powerful ones? I used to have my flame door opened on my other RVs. Now I don't.
Same for verifying clearance from back of refrigerator to outside wall. Too much is NOT good. It is all in your refrigerator installation manual. - wopachopExplorerDoubt the fella in AZ is boondocking with fridge on propane.
Your stove is pressurized with propane. How many people turn off the tanks before bed?
The hole you make to add cold air behind the fridge will be higher than the lowest vent. If there was a propane leak, it would fall down and out the trailer.
If any of this seems confusing or dangerous then dont do it. If you are somewhat mechanically inclined and able to think for yourself then determine if you see an actual risk. This is not a daily ritual. Its just when temps get to scorching level and the absorption fridge just cant cool when its getting 100F air up the backside. - lostbytesExplorer
wolfe10 wrote:
wopachop wrote:
Not the safest approach but if youre living inside the unit with your AC running figure out a way to let the cold interior air enter the back section of the fridge. Ive been doing that for awhile. Most people dont really understand the concept. It works pretty good if you are already spending the money to cool the inside of your trailer and stuck with an absorption fridge. You can vent 80F degree air up the back of the fridge instead of 110F.
The most important statement is the first one: NOT THE SAFEST APPROACH.
Propane can leak when refrigerator is running on propane. It could also start leaking when it is not running from the propane connections and solenoid in the back of the refrigerator.
PLEASE don't do this, particularly if the vent is lower on the inside than the location in the back of the refrigerator, as propane is heavier than air and will happily descend into your interior.
To add to the above statements. If you use a fan in the back. Make sure propane RUNNING FLAME or pilot flame will not be interfered with. Those computer type fans should be ok but more powerful ones? I used to have my flame door opened on my other RVs. Now I don't. - wolfe10Explorer
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
