Tom_M1
Jul 06, 2016Explorer
MEXICOWANDERER wrote:A dash switch typically is different. It's usually a momentary switch that is pressed to jump the coach batteries to the engine battery in the event that the engine battery is dead. Once started you release the switch.
"when you forget to disconnect from the engine battery"
A dash switch is different? My recommendation is to suffer testing all those "BIRD" points with a meter (while holding a troubleshooting guide) to the maze of connections to find the problem.
The diagram I posted is overly complicated because they included two battery disconnect solenoids.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
