MEXICOWANDERER
Jul 08, 2016Explorer
This is a Ford type fender mounted starter relay. This is the one and only type of relay to use when paralleling battery banks to jump start the engine. It is referred to erroneously as a solenoid. Solenoids move something and they also may make electrical contact. One full-on jump start will crispy-critter a standard constant duty relay's contacts.
Be sure to run terminal and wire from either of the relay's mounting ears to a good chassis negative "ground". Otherwise it won't work.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
