pianotuna
Jan 04, 2022Nomad III
1L243 wrote:
I have a shunted battery monitor. It gives you alot of information. In setup one of the parameters is to input the amp hours of your battery bank.
Should I input the total 340 amp hours into the parameters settings of the monitor and just figure out as I have been doing or should I input the actual useable amp hours like 170 amp hours?
It depends on if the meter uses a peukert calculation or not. If it does then use 340 OR do a full capacity test and use that number.
