EMD360
Jan 10, 2022Explorer
Interesting. I switched to lithium with the new Victron battery monitor and read that a little under full was a good “safety measure” so I started with 100 ah instead of 110. At some point I changed to 110 because I was getting confused. And the reset to full can happen when they are not as full as other full readings. But I seldom get the batteries down below 50% because the solar at least trickle charges them. (360 watts on roof) at that level the voltts are still above 12 because lithium’s keep up voltage until they are closer to exhausted. I have cut off set at 80%. It does have a peukart setting but for lithium’s it is set low although I don’t remember exactly. I also found the exact settings for the Lion batteries on their website which removed guesswork. One great side effect is really not having to pay too close attention when boondocking.
