topwater1956
Aug 16, 2017Explorer
We Cant Wait wrote:
Might need to contact Freighliner for the correct height, and where to measure it from and too. Also most ride heights are measure with the suspension fully aired up. Also you might want to weigh the unit, and then check the tire makers specs for air inflations.
Thanks, but Freightliner said they couldn't find it in their system. I know you measure from the bottom of the frame rail to the center of the bottom shock bolt with the bag aired up atleast 60 lbs and I think its 10", but that's only 2" from where I'm at now with the air bags empty and setting on the stops. I think it will bottom out with just 2" of travel.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
