trm3650ExplorerOct 01, 2020short in wiringhello, newbie here. say i am working on my jayco, i keep blowing a 15 amp fuse at the convertor, it goes to the A/C unit and the furnace, and of course the wall thermostat.as soon as i put in a new fu...Show More
wa8yxmExplorer IIIOct 01, 2020One trick you can use involves a license plate lamp socket (The kind with two leads) and a Dash indicator lamp that will fit in the socket.Put "Tab" type connectors (The flat type) on the ends of the leads and plug int lamp in in place of the fuse. Now you can hook and unhook stuff till you find out what is shorted.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related ContentFleetwood Angler wiring2005 SixPac D850 WiringAdding power outlets in slide with no wiringBad tail light wiringShort But Powerful
