- otrfunExplorer II
korbe wrote:
One of the nice things about the Progressive Dynamic converters (with the pendent) is being able to verify the charging mode at a glance. Once the batteries are charged it should remain in float or maintenance mode to prevent overcharging. Have you checked your converter's output voltage output when the batteries are fully charged to verify it's actually entering and staying in float mode?westend wrote:
Maybe what I have seen, batteries wet on the top, and having to add water quite often, is not overcharging. In my mind, I felt that it was. So I installed the switch and haven't needed to add water in over 5 years. My batteries are 8 years old with no signs of giving up yet. I will not tell anyone here to do anything but I will let people know what works for me.korbe wrote:
Since the bulk charging specification of a T-105 is 14.8V, you must be having a converter malfunction to overcharge them.
When I first got my 6-volt T105's I watched them closely while connected to shore power. I found they overcharged even with my 3-stage converter. So I installed a disconnect switch and now when I plan on being on shore power for more than a couple days, I disconnect them. Everything still works just fine. And that is how my system works. Every system works a little bit different and to monitor your battery situation is always a good start.
Also, if a battery is left with no charge present, it is sulfating. It can be argued just how severe that is and what effect it has on batteries when intermittent charging is in place but it does remove some battery longevity (compared to the other situation,i.e. always having charge voltage present).
A drop in electrolyte level is customary and, if not excessive, does not mean batteries are being "overcharged". - red31ExplorerYes, disconnect and let SOLAR maintain your battery, one with the 3 characteristics stated above.
- CA_TravelerExplorer IIIWith a good multi stage charger that maintains the proper voltages the battery will vent very little until it reaches the end of life.
But 3 things are required for this to occur:
1. The charger must be designed to charge your batteries to their mfg specs vs some generic battery type - flooded being the most common.
2. The charger must be adequately wired to the batteries which means that it is very close or very heavy wire is used. Many RVs fail in this regard.
3. The charger must have a remote temperature probe on the batteries unless you are always at the optimal temperature per mfg specs which is about 70F+. The temp probe provides the necessary data for the charger to adjust the charging voltage.
I've seen my float charge vary from 13.1V to 13.9V depending upon temperature. - BFL13Explorer IIThe OP said in the OP he has a PD converter. Not sure if he has the Charge wizard for it. If not, he has a single voltage 13.6v converter. (or maybe that is just for Iotas ?)
It does not need a battery. But if you have a trailer you must have a battery for when towing it, so really the question for trailer RVs that are always on shore power, never off-grid camping, is all about how to keep the "towing" battery alive between trips. - CA_TravelerExplorer III
skipro3 wrote:
There is some really TERRIBLE advice on this thread.
First, your RV has a 12 volt CHARGER. It is NOT meant to run ANYTHING. It is meant to charge your batteries.
Incorrect. The charger supplies amps to the house loads first and any remaining amps will charge the battery as required. Only when the house amps exceed the charger capability is there draw from the batteries.
Your batteries run the 12 volt stuff. If you try to run your 12 volt stuff off your charger without batteries bad things can happen to the 12 volt stuff AND to the charger.
Depends upon the charger as some are designed to operate w/o the battery. skipro3 wrote:
First, your RV has a 12 volt CHARGER. It is NOT meant to run ANYTHING. It is meant to charge your batteries. Your batteries run the 12 volt stuff. If you try to run your 12 volt stuff off your charger without batteries bad things can happen to the 12 volt stuff AND to the charger.
If you don't believe me and you need specifics on how or why a charger system is not designed to run loads, then go do the research.
Second, there is no reason to disconnect your batteries during the normal life of the RV unless maintenance or replacement is required. Even flooded batteries do not need to be disconnected from the charger. Doing so in order to keep electrolyte from evaporating is bad maintenance. Regular check on the battery electrolyte is required for flooded batteries. Trying to avoid this by disconnecting the batteries from the charger is bad and lazy and likely to end up with dead batteries when you forget to plug the charger back in.
HOW do you know what the OP has?????? I have NEVER seen a Converter that is ONLY a Charger(37 years as a tech, still a Tech). They are CALLED Converters, NOT chargers. That is why you can have CONVERTERS OR a Inverter/CHARGER which IS a charger. Doug
PS, you ARE correct that there is BAD ADVICE. YOU are one of them.skipro3 wrote:
Actually Progressive Dynamics (intelli-power) is designed to run an RV with no battery connected.
And BTW the converter holds voltage of the RV above 13.2 volts in which case NO power will come out of the battery. Discharge will not happen until voltage sags below 12.8 volts.- RJsfishinExplorerQuote:
Really now ?
Shows to go you how much you don't know !!
Any converter that is standard in any RV, is a power suppy, whether you want to believe it or not. It is not a battery charger, but it does charge the battery. - korbeExplorer
Maybe what I have seen, batteries wet on the top, and having to add water quite often, is not overcharging. In my mind, I felt that it was. So I installed the switch and haven't needed to add water in over 5 years. My batteries are 8 years old with no signs of giving up yet. I will not tell anyone here to do anything but I will let people know what works for me. - Ski_Pro_3ExplorerThere is some really TERRIBLE advice on this thread.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
