Groover's avatar
Groover
Explorer II
Dec 08, 2021
Should I upgrade to a Magnum 3012RV inverter/charger
My coach came with a Magnum 2012 modified sine wave inverter charger which for the most part has worked well but my microwave oven makes terrible noises when running off of it and I would like to be able run an air conditioner occasionally without starting the generator.
The 3012RV hybrid unit seems like it should solve both issues but I saw a recent thread about issues starting an AC on this inverter. There was a comment that Magnum does not recommend powering an AC with the 3012 but I haven't been able to find anything in the manual to support that.
When comparing the specs between my 2012 and the 3012 hybrid it appears that the 3012 is less efficient but I am not sure how big of problem that actually is.
I have been told that Victron makes better charger inverters than Magnum but I like the idea that the 3012 appears to be a bolt in direct replacement for my existing unit. I am hesitant to tackle the job of wiring in a different brand, especially wiring the remote control for it. Maybe the control cable is an industry standard and can be re-used for a Victron?
I have already upgraded my batteries to 640 amp hours of lithium iron batteries that are capable of a 1C discharge rate so that shouldn't be an issue.
Any informed thoughts from someone with experience?
Having RV issues? Connect with others who have been in your shoes.24,267 PostsLatest Activity: Jun 14, 2025
