- ps2000Explorer
dougrainer wrote:
ps2000 wrote:
Also does it have to be the specific regulator for my stove, or are they pretty universal?
I have a Maytag/Magic Chef. Would say an Atwood regulator work?
As long as it is a 10" W/C pressure regulator. Doug
Ok. Because the one specific part for my stove is 100. But I can find Atwood regulators for 40. Wondering of I can stick an Atwood on. ps2000 wrote:
As long as it is a 10" W/C pressure regulator. Doug- Old-BiscuitExplorer III
Best thing is to use MODEL No and search for the CORRECT part number
Search HERE for part #
Then you can purchase there OR do further searches for pricing using the correct MFG> part number
And NO...you would not be able to feel/detect air coming out of vent as it is at atmospheric pressure NOT pressurized and blowing out.
Anything causing bubbles (leak test) or that you can feel is Propane blowing out under pressure. - ps2000ExplorerAlso does it have to be the specific regulator for my stove, or are they pretty universal?
I have a Maytag/Magic Chef. Would say an Atwood regulator work? - aruba5erExplorerNO NO NO and NO. the diaphragm is shot. Replace the regulator.
- ps2000Explorer
dougrainer wrote:
1. There is NO allowable leak on any LP system or appliance
2. The Range/Stove Regulator is required and should NOT leak. It is a 10 inch w/c regulator as this appliance runs on less pressure than the rest of the RV (which is 11.5 w/c).
3. ANY leak on a part, you replace that part. Doug
So now I need to find the part :) Any recommendations? - 1. There is NO allowable leak on any LP system or appliance
3. ANY leak on a part, you replace that part. Doug - wa8yxmExplorer IIIShould the regulator leak?
Short answer: NO
Long answer: well, it's still NO, just restated about 100 different ways. - westendExplorer
ps2000 wrote:
Old-Biscuit wrote:
Vent primary purpose is to allow air in/out as diaphragm moves.
Secondary purpose......to ID cracked/leaking diaphragm
REPLACE..before using system again.
So the leak I see is not just the diaphragm letting out air right?
If it's a continuous leak, you need to replace the stove's regulator. The diaphragm only moves a fraction of an inch, initially, to establish correct delivery pressure. - ps2000Explorer
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
