Terry_25ExplorerFeb 12, 2020Sinarek closet. SlideSounds normal. Goes out 2 inches and stops. Other large slide worked. Tried repeatedly. Same result. Fuses good. Checked carefully for obstructions but is c!ear. What else can I check. Thanks
Corkey05ExplorerFeb 12, 2020Could be a low voltage issue. Check (and clean) all your connections and pay special attention to the ground connection.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentAdding power outlets in slide with no wiringSliding closet Doors in fifth wheelCloset door mirrorsarctic fox slide adjustmentmirrored closet doors?
