Terry_25ExplorerFeb 12, 2020Sinarek closet. SlideSounds normal. Goes out 2 inches and stops. Other large slide worked. Tried repeatedly. Same result. Fuses good. Checked carefully for obstructions but is c!ear. What else can I check. Thanks
joebedfordNomad IIIFeb 13, 2020Assuming you mean Schwintek (I've never heard of the thing you tyoed) you can use the manual override to bring out the slide. However, it sounds like you have some kind of obstruction.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
Related ContentAdding power outlets in slide with no wiringSliding closet Doors in fifth wheelCloset door mirrorsarctic fox slide adjustmentmirrored closet doors?
