The ceiling in the slide on our 2008 Laredo 5er is sagging slightly on both sides of the lights. There are no signs or smells of water. We are concerned that there might be some nasty problem. Any tho...
If the ceiling construction is like my lightweight, there is a layer of foam (about 1 1/2" thick in my case) between a thin lauan roof layer and a thin lauan ceiling layer. The inner ceiling layer (probably less than 3/32" thick) might have delaminated from the foam and is sagging down. This could happen even without water intrusion.
Can you see if the roof is also sagging down in the area where the ceiling is sagging?
Just a thought on a possibility.
Steve
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
