JoshInReno's avatar
JoshInReno
Slide Electrical Issues
Hi everyone, it's been awhile.
I have a new to me trailer and have run into a problem:
The bedroom slide will not move on 12v power. It just clicks. The kitchen slide works fine on 12v so I don't suspect the battery but it's possible.
The bedroom slide works fine on 120v so I assume the motor and gearbox are fine. It should be noted I have yet to even find the motor and gearbox. The slide has arms, not cables so I suspect the drivetrain is under the slide but it's an enclosed underbelly that I don't want to start cutting into just yet.
Any ideas?
  • Check the circuit breakers on the trailer tongue. If they are weathered and have any corrosion on them replace all of them. Not hard to do.
  • All systems on the trailer are 12 volt. Since it operates when plugged in, it will be a battery issue. Have your battery tested, if over 3 years old, replace it.
  • Try looking under the bed, some will have a false bottom covering the motor
  • Low battery voltage. If it works when plugged in the converter is putting out 12 volts to operate your motor. Check wire to battery and clean if bad.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 06, 2025
