MrWizard
Aug 02, 2014Moderator
You do have a meter with ohms scale
Make a connection chart start with the old switch
Switch of measure all wires to other wires, red to blk, red to green ,red to white etc.. Then green to bulk, gen to whit.
Now switch in and measure again
Switch out measure again
Write all of it down
Do it again with new switch
It's not about wire colors
It's all about which connections close , when going one way or the other
Once you have it written down, you can match toe open and closed connections in each direction to the correct color wires
Example red and green connected on old switch might pressed "IN"
Might match yellow and people connected when pressed "IN" , on new switch
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
