MEXICOWANDERER
Aug 03, 2014Explorer
Gimme my nickel and I'll give it back as a reward BFL13. The possible admonishment was actually intended for "eyes other than yours"
This forum is an aggregate total vital resource of ten thousand and ten things, references, how-to's, links, knowledge and experience. I study heater, water heater, AC, generator, inverter threads for useful comments. It is a learning center for me.
BTW: I just purchased 100 star shaped LED 10-watt heatsinks for 1,100 lumen Bridgelux 10-12 volt LED chips. Total price delivered under two hundred dollars.
No fan needed. Now the hunt is on for exceptionally low priced drivers.
I am going to try clear gel-coating the chips once they are mounted. For corrosion resistance. This is going to be fun.
I am going to try and series connect 4 33 volt 50 watt chips, isolate with a 6 amp 1KV rectifier span a 100 uf cap across the rectified potential and pluggerin.
"This is the North American Command (Omaha). Out bird just captured a double flash at 22 degrees latitude -possible nuclear event"
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
