BFL13's avatar
BFL13
Explorer II
Aug 02, 2014
Slide In/Out Switch Wiring Help Please
(I am on limited internet while camping or I could spend the MBs looking this up myself, so if anybody has nothing better to do, please look this up and give me the link so I can go straight to that and see the right wire to wire diagram or description, thanks)
OK , I am replacing the original Lippert switch with one I got at an RV shop. The package does not give a wiring diagram. Rats.
Lippert
- Green switch wire to red motor wire (outboard wire at IN end)
-Red switch wire to black motor wire (outboard wire at OUT end)
Note: actual motor has two wires one red one white- the "Lippert" red and black "motor wires" go to these two wires.
-Black wire to battery positive (middle wire)
-Two whites on switch combined at the trailer white to ground wire
RV Care (rvcare.ca) Switch (Made by American Technology Components)
-Outboard wire at IN end- black
-Outboard wire at OUT end-red
-Middle wire-green
Second wire in at IN end -yellow
Second wire in at OUT end-black
I have tried various ways and got either the IN or OUT to work but never both, plus I have burnt out four 30a fuses so I have given up fooling around. :(
Monday is a holiday here so I will have to wait till Tuesday to go back and get a wiring diagram or else maybe one of you good folks can give me a steer to the right way to match these wires. (five switch wires, four trailer wires.) Thanks.
  • MEXICOWANDERER wrote:
    Betcha nickel he doesn't bother to take a photo of it......
    Correct. I did an ink amendment to my Lippert wiring diagram in the handout we got with the trailer. :)
    Mr Wiz is also correct that I should have been able to figure it out from first principles as he first posted, but you need a working brain for that.
    I suppose it is too much to ask for them to put a wiring diagram in the package the switch comes in. Oh well.
  • Gimme my nickel and I'll give it back as a reward BFL13. The possible admonishment was actually intended for "eyes other than yours"
    This forum is an aggregate total vital resource of ten thousand and ten things, references, how-to's, links, knowledge and experience. I study heater, water heater, AC, generator, inverter threads for useful comments. It is a learning center for me.
    BTW: I just purchased 100 star shaped LED 10-watt heatsinks for 1,100 lumen Bridgelux 10-12 volt LED chips. Total price delivered under two hundred dollars.
    No fan needed. Now the hunt is on for exceptionally low priced drivers.
    I am going to try clear gel-coating the chips once they are mounted. For corrosion resistance. This is going to be fun.
    I am going to try and series connect 4 33 volt 50 watt chips, isolate with a 6 amp 1KV rectifier span a 100 uf cap across the rectified potential and pluggerin.
    "This is the North American Command (Omaha). Out bird just captured a double flash at 22 degrees latitude -possible nuclear event"
  • The new switch got the last laugh anyway, even though the wiring diagram is clear. Murphy's Law.
    The motor has two wires (red and white) and the red and black wires from there to the switch place inside the trailer have to be connected at the switch end for IN and OUT.
    It doesn't matter what the switch's wiring diagram says for the red and black wires to the motor because for sure, whoever put the red and black wires on the motor's red and white wires will nave done them the other way around! Argghh!
    So put those two wires at the switch on last after the pos and neg wires are connected. Then you can play trial and error to find out which one is really IN and which is really OUT. :(
  • Hopefully you have figured it out now. This link to American Technology may help. American Technology slide & awning switches. Same switch.
    I just installed a new awning and a slide switch. The switches were a little different as I got them from different sources. I couldn't figure one out at first and then discovered that you need to jumper two of the terminals together to make the polarity reverse properly. They are just a DPDT switch and I think one has an internal jumper and one doesn't.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
