M_GO_BLUE1's avatar
M_GO_BLUE1
SLIDE MOTOR RELAY???
Just pulled into our RV site and one of our slides does not want to go out...
It started about 2 inches then stopped...thought it was the fuse but the fuse is good...BUT IN THE FUSE BOX ARE RED LIGHTS BELOW EACH FUSE AND WHEN YOU PUSH THE BUTTON IT CLICKS AND THE RED LIGHT IS ON UNDER THE FUSE FOR THE SLIDE MOTOR
Is the the relay or what?
Also the slide covers one of my four vents for the furnace...can I still run the furnace?
ANY IDEAS OR SUGGESTIONS ARE WELCOME...
  • Ended up being a loose wire that was eventually found by taking off a panel underneath the trailer and looking at the motor...
  • We did swap the fuses and both work...
    Batteries are fully charged and everything 12V works when not plugged in...
  • If one works and the other doesnt you can swap the fuse for testing.
    Check all the wiring.
  • I am surprised the slide is wired through the fuse panel, but the LED basically says the fuse is not conducting current. It could be a fuse that looks good but is bad, or it could be the fuse holder itself is bad. I would try a new fuse, make sure it fits tightly in the fuse holder, and if that doesn't work, move the lead to another fuse position.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
