The guy across from me in the RV park has a 2005 Jazz, by Thor. His slide will go in, but not out. He's thinking probably a switch issue. What do you think? Also, if he has to manually crank it ou...
It could be the switch. They wear out. Replacement Lippert switch has different colour wires than the old ones, so see their website first to get the wiring diagram, or go nuts. BTDT. :(
If the motor does not have the extension rod and there is no hole, then you would have to turn it right at the motor.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
