waynefi's avatar
waynefi
Explorer II
Jul 14, 2019
Slide out motor problem
The motor that pushes out my slide was connected to the interior wall of the TT with 4 1/4 in sheet metal screws. That actually lasted 7 years before they pulled out. I did a temporary fix by using 5/16 screws, but what is the permanent fix?
Hollow wall anchors might work, but are they strong enough? The hollow part of the wall is 1 inch, some anchors need more than that. Some anchors need the wall to be at least 1/8 in thick, this is less than that. So what would hold?
  • waynefi wrote:
    Unfortunately, I can’t get to the back side. The solution may be to screw the motor to a plate of some kind and then screw it to the wall with more than four screws.
    Well you can up with a common solution.
  • Unfortunately, I can’t get to the back side. The solution may be to screw the motor to a plate of some kind and then screw it to the wall with more than four screws.
  • If you can get to the back side of the wall, then thru bolt and put a metal plate on the back side. One of those reinforcing thin metal nailing plates would work. For extra points epoxy the plate to the wall
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
