Bob_Shaw's avatar
Bob_Shaw
Slide-out motor problems
I have a 2008 Pilgrim Open Road 5th wheel and my bedroom slide-out stopped working. I traced the electronics to the motor, and I had juice all the way to the motor. So, I ordered a new motor, which was quite an experience with an old orphan unit. Part numbers were superseded, and no one kept up with what number coincided with the old.
Since my new motor is now on the way, I decided to test something that had been bothering me...I never tested the motor itself. So, I tested it... and it works. I tested it on the bench and it worked in both directions, so I got my jumper cable and connected the motor, via the jumper cable to the trailer wiring, and yes, it worked. Yes I did try turning the manual slide gearing to make sure there was nothing binding or hung-up there.
Ok gurus, what's going on? Do I just have an old motor that won't work under load, or am I looking at some other issue? When installed, the motor wouldn't even click or make any sound that I could hear. I just don't know what I'm dealing with at this point. Any ideas? What other information could I give you to help diagnose the problem? I'd hate to put the new motor in and find-out it still doesn't work.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
