Ok the problem is that my small slide will come in until it is tilted so much it will not move have ho pull the top in and have someone push switch to get it to come in any sudjestions I was hooked up...
Appropriate lubrication does wonders too. Slides are finicky mechanical beasts, and like other objects that need regular maintenance, the right lube in the correct locations usually corrects the issues.
Unless there's damage due to the lack of lubrication and/or other causes...
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
