dougrainer
Apr 22, 2020Nomad
Can't get to the Photo. BUT, the WIPE seal is just that. It fills the gap between the hole cut out and the sidewall of the Box of the room. It does NOT and IS NOT meant to SEAL the room but wipe when going in and out to cover the gap. If the room does NOT leak when extended or retracted, I would NOT worry about it. Someone mentioned a 1/4 inch gap, which is not a big concern. The actual room seals are called D seals and those are what seal the room when extended or retracted. Doug
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
