way2roll
Apr 22, 2020Trailblazer
happy2rv wrote:dougrainer wrote:
Can't get to the Photo. BUT, the WIPE seal is just that. It fills the gap between the hole cut out and the sidewall of the Box of the room. It does NOT and IS NOT meant to SEAL the room but wipe when going in and out to cover the gap. If the room does NOT leak when extended or retracted, I would NOT worry about it. Someone mentioned a 1/4 inch gap, which is not a big concern. The actual room seals are called D seals and those are what seal the room when extended or retracted. Doug
Agree with Doug here. I don't think you have anything to worry about as long as everything is square and the actual seals are functioning correctly. The rubber "seal" in the picture isn't meant to be a water tight seal. It helps wipe water away if the slides are wet when retracting them. I wouldn't worry to much about it if it were me. You might look at this while retracting the slides to see if it makes contact while sliding in. They will get sucked inward as you retract and pushed outward as you slide out so they may be closer after cycling the slide a couple of times.
I must have mis-read. I was guessing he was talking about the D seals, not the wipe seals. I can't see the pic either.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
