albow
Apr 23, 2020Explorer
way2roll wrote:Got my answer apparently but had to reply to you about this. I thought I was told to let go of the slide button as soon as it bottomed out. It does sound as though they grind on the gears until you let go after bottoming. I wonder if it's different with hydraulics, which mine aren't?
A lot of slide motor manufacturers will tell you to "re-sync" your motors. In both RV's I had which were Schwintek motors, you had to hold the button an additional 10 seconds after the slides were in our out to ensure they remained in sync. Not sure if that helps but worth a try.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
