dougrainer
Apr 23, 2020Nomad
albow wrote:way2roll wrote:Got my answer apparently but had to reply to you about this. I thought I was told to let go of the slide button as soon as it bottomed out. It does sound as though they grind on the gears until you let go after bottoming. I wonder if it's different with hydraulics, which mine aren't?
A lot of slide motor manufacturers will tell you to "re-sync" your motors. In both RV's I had which were Schwintek motors, you had to hold the button an additional 10 seconds after the slides were in our out to ensure they remained in sync. Not sure if that helps but worth a try.
IF you have Schwintek slide system, ALWAYS hold the wall switch for 10 to 15 seconds after full extend or Retract. That re-synchs the motors everytime. IF you hear gears racheting, you do NOT have a Schwintek. The Racheting is the clutch in the motor system and this is normal. Doug
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
