Randu
Dec 21, 2013Explorer
Slides always operate off of 12volt (battery) no matter if hydraulic or electric motor. Hydraulic uses 1 motor to run the hydraulic pump to operate multiple slides. Multiple motors(1 per slide) are used if rack an pinion or cable operated. Shore power (110volt) runs the converter that charges the battery to make everything work. Sometimes you can run the slides without a battery when plugged in if motors don't draw more amps than the converter puts out. Randu
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
