dougrainer
Dec 21, 2013Nomad
JOHN5206 wrote:
Do the slides run directly off the house battery, when hooked to shore power?
If 12 volt electric motor slide system, then NO. The battery is usually required to be installed and charged up, but the slide system is wired to the 12 volt breaker panel supply. Most slides require both a charged up battery AND connected to 120 shore Power(Power Converter) for optimum operation. Very few Slide systems are wired direct to the 12 volt battery posts. Doug
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
