dougrainer
Dec 22, 2013Nomad
RJsfishin wrote:
Mine run off the chassis battery
Are you positive? Some think since the engine or key must be ON and the parking brake set, then the chassis supplies power to the slide motor. But, MOST OEM's wire the actual slide motor system to the coach, but have a relay that requires the Chassis system to be engaged to operate the slide room. Doug
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
