RJsfishin
Dec 22, 2013Explorer
dougrainer wrote:RJsfishin wrote:
Mine run off the chassis battery
Are you positive? Some think since the engine or key must be ON and the parking brake set, then the chassis supplies power to the slide motor. But, MOST OEM's wire the actual slide motor system to the coach, but have a relay that requires the Chassis system to be engaged to operate the slide room. Doug
Yep, positive, I can see it. But probably only because the chassis battery is close to the pump. The house batts are 12ft away.
But, in actuality, once the key is on, its running off all the batteries.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
