Used MH for the last time yesterday and neither slide will move. Kinda put a damper on wk/end as we were 80 miles from home and it was raining.the HI AMP breaker was not tripped,the seat switch althou...
If the batteries are not fully charged or not in good shape, they could be your problem. As an experiment, start the generator, let it run for a few minutes and see what happens while it's running. At startup, a large charge / amperage should be going to the batteries and also available to the slide motors. If the slides now work, either the batteries aren't charged (or holding a charge) or try cleaning the connections because you're not getting enough power to the slide motors.
Bill
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
