s79vette
Oct 20, 2013Explorer
slide power
Used MH for the last time yesterday and neither slide will move. Kinda put a damper on wk/end as we were 80 miles from home and it was raining.the HI AMP breaker was not tripped,the seat switch althou...
Trackrig wrote:
If the batteries are not fully charged or not in good shape, they could be your problem. As an experiment, start the generator, let it run for a few minutes and see what happens while it's running. At startup, a large charge / amperage should be going to the batteries and also available to the slide motors. If the slides now work, either the batteries aren't charged (or holding a charge) or try cleaning the connections because you're not getting enough power to the slide motors.
Bill
