Used MH for the last time yesterday and neither slide will move. Kinda put a damper on wk/end as we were 80 miles from home and it was raining.the HI AMP breaker was not tripped,the seat switch althou...
It's an Equalizer jack and pump system and pump works good. The control buttons are not telling solenoid to fire as if there is no 12vdc at switch and can't find a fuse marked "slides" and there are no Hi Amp breakers open. will try emerg. brake to see if that works, never had to use it in the past and I've owned MH since new.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
