Used MH for the last time yesterday and neither slide will move. Kinda put a damper on wk/end as we were 80 miles from home and it was raining.the HI AMP breaker was not tripped,the seat switch althou...
My HWH slide/jack system was good at intermittently not working, and for no reason......IMO
So w/ help from someone here, I installed a pushbutton switch on the dash, which grounds the pump sillynoid, which in turn bypasses all the safety devices in the system. Now whenever the pump doesn't operate, I just hold the pushbutton and everything operates normally.
Maybe this could work for you.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
