wa8yxm
Jan 26, 2016Explorer III
Had the same issue with my steps.> your motor has developed a "Dead Spot" now in the case of my steps which have hard stops I was able to "Re-Index" the motor so it stops on a different spot (basically I opened the trans and moved a gear a couple notches) Do not know if you can do that with your slide, but you may wish to replace the motor.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
