Lakejumper's avatar
Lakejumper
Slideouts Work Sometimes don't Work
I'm camping with a friend who owns a 2004 Adventurer 38R (Class A Motorhome) that has a hydraulic bedroom slide and an electric living room slide. When she departed from her destination yesterday, the slides retracted normally. She drove about 3 hours and when she arrived yesterday, both slides wouldn't go out. The engine was running and the parking brake was engaged. The dash radio and phone USB port wouldn't work either. Today, Took the RV to have the two 6 volt house batteries checked by an auto mechanic and they were fine. The slides wouldn't work at his shop. After she drove back to the RV park, the slides went out with no issues. The radio also started to work again along with the phone USB port. I had noticed yesterday that there was a lot of corrosion on the battery brackets and they were a little loose when I looked at the battery.
What could be causing this intermittent problem? Could there be a loose wire/ground that is causing this and where would it be located?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
